Hi, due to customer request I tried to build a Self Service pkg for Anaconda 4.3.1 ( https://www.continuum.io/downloads#osx )
For the creation I used a clean machine running macOS 10.11.6 El Capitan used Composer and made a snapshot (before and after the installation) . Afterwards I defined the scope in the jss and deployed it using the self service.
So far so good - the installation went well on the target machine and I can use the conda commands via terminal but if I try to run the Anaconda-Navigator alias in the Applications folder it just pops out for a few seconds but the web-frontend won't open. The console is showing this : com.apple.xpc.launchd[1]: (com.continuum.io.136672[3194]) Service exited with abnormal code: 1
Any suggestions what went wrong and how the desired result can be achieved?
Thanks in advance
Best,
Simon
Any luck on this? I'm facing the same dilemma. I haven't been able to look into it in too much detail yet, I'll share any findings.
I'd be interested too. Just ran into this same issue.
