So, we are thinking of testing the DEP in our organisation. However, since we are an educational establishment, we are working primarily with students from age 11 - 15. These students often tend to forget their iPad passcode lock (which is forced with a configuration profile on all student iPads). More often than not, the Wi-Fi on that device is also turned off, and cannot be turned on unless unlocked first. At the moment, the iPads are supervised via a Configurator machine. So, for the moment, we can connect an iPad in that state, remove the MDM profile, which unlocks the iPad, and then reinstall the MDM profile.
My question is, how does one unlock an iPad that is supervised over the air with DEP, when there is no Wi-Fi and the Wi-Fi cannot be turned on on the device?
P.s. we know about the ethernet connection on the iPad, but it's not the "officially supported" way.
