How to import excel data in Jamf pro?
  • July 11, 2023
  • 3 views
I created a smart group to get the list of devices inactive > 180 days, but then there lot of devices ready for deployment and after exclusion we identified 150 devices whose license we can safely remove
But the issue is to how to create a smart group or static group by importing the data from excel ?
Best answer by sdagley
@Sonam2021 The MUT tool will allow you to create a Static Group from a .csv file created by Excel. Smart Groups aren't intended to be based on a static list.
1 reply
sdagley
  • 3540 replies
  • July 11, 2023
Cookie policy
Cookie settings
