How to set up an application at system startup
  • June 15, 2015
  • 10 views
Hi Support,
I am Zhang Bin from DMG (China)
I need soma assist on how to set up an application at system startup, start automatically, or let the application generate a shortcut in OS desktop. My system JSS 9.72
Your advice much appreciated!
Thank you.
Best regards,
1 reply
  • June 15, 2015
@Bin_dmg
you can perform one of two things : Create a config profile
select the login items items
then add the path to the app bundle
Or you can create a launch agent in the /Library/LaunchAgents folder which would also work.
let me know if this solves your question
