How to view systems that are assigned to a static group
  • November 2, 2018
  • 6 replies
  • 96 views
I feel like I am missing something in the GUI. I have a static group that I use to apply specific settings to systems temporarily. I have evidently forgotten to remove 7 of the systems from that group.
How can I find the systems that are assigned in that group. I would not consider paging through my 6000+ systems to be a user friendly option. I can use the API's to get a list of these systems which again I would put into the not user friendly option.
Am I just missing something obvious in the GUI on how to do this?
Thank you
Best answer by mmcallister
Hi Rob,
If you click above the checkbox column in Assignments, you can sort by assigned/unassigned.
  • November 2, 2018
Login to the web interface.
Computers > Static Computer Groups > Select your group > View
Shows members, no?
  • November 2, 2018
Are you not able to open up the Static Group and view the membership there? After the group loads (which can take a while), there should be a "View" button that you can select that shows you just the machines that are in that Static Group.
Granted, you will still need to go back to the Assignments tab once you note which machines are still in the group, to remove them. The membership view doesn't have a way to edit it in place. But it should filter out just the machines you have to locate out of your 6000+ total clients.
  • November 2, 2018
Thanks. I should have been clear the end goal is to remove the systems from the group. View the static group and jotting down the machine names to filter to so I can uncheck was basically what I was trying to avoid.
I guess I will put in a feature request that Jamf use basically the same UI for group assignments that they use for policy assignments. I can easily remove a system that has been added to a policy in basically a single step. I just wanted to be sure I wasn't missing something.
Thank you
  • November 2, 2018
Hi Rob,
  • November 5, 2018
I swear this did not work last week, but it is now. Maybe a new feature in 10.7.1 as I did upgrade. Anyway, thank you.
sdagley
  • November 5, 2018
It works in 10.5.0 as well. Thanks @mmcallister!
