How to view what policies are scoped to a Static Group
  • April 6, 2017
  • 39 views
Is there any easy way to find out what different policies and configuration profiles a Static Group is scoped to? At the moment, it seems like you would have to check the all policies and profiles individually.
If there isn't a way, consider this a FEATURE REQUEST.
  • April 6, 2017
There is a feature request for this for Smart Groups, so I would assume it is the same for Static Groups.
I too would be interested to know if anyone has figured out a way to do this for either Smart or Static groups?
janzaldua
  • December 18, 2022
I would still like to know this as well. For each computer, you can view the Policies they are a part of. But for each Static Group, there seems to be no option to few what Policies they are a part of.
