HTTPS Distribution Point
  • January 25, 2010
  • 6 views
Does anyone have any idea of why when I changed my Dist. Point from HTTP to
HTTPS and changed the port form 80 to 8443 that all of my policies fail
stating that they cannot verify the download? I know for a fact that is
isn't downloading anything because that error comes up almost immediately
when I run a policy. I do see that it is trying to use HTTPS and 8443 but
it still fails. I may just need to put in a support call, but since it was
after 5pm, I figured I would try ya'll first.
Thanks
Alan
Alan Benedict
Macintosh Technician
The Integer Group
O: 515-247-2738
C: 515-770-8234
http://www.integer.com
1 reply
  • January 26, 2010
HTTPS indicates that there’s a certificate exchange going on in one form or another. Are you using a self signed cert? It sounds like there’s some sort of cert issue going on. Can you wireshark it? Obviously, you won’t get the content of the packets, but you’ll get the handshake.
J
