Importing machines from Remote Desktop to Casper
SEN73
New Contributor
Hi All,
We use Remote desktop at the moment and have just recently introduced JSS/Casper into the environment my question is how would you go about importing all your machines from remote desktop to JSS/Casper?
Thank SEN73
1 ACCEPTED SOLUTION
Legendary Contributor III
Build a QuickAdd package with all your pertinent details set up in it from the Recon.app, then push that package to all your Macs in Remote Desktop.
Done.
Edit: Corrected to Remote Desktop.
3 REPLIES 3
Done.
SEN73
New Contributor
Much Appreciated mm2270 :)
Still learning this beast
thanks again
SEN73
New Contributor
thanks again
