We are looking to expand the file distribution point for macOS and potentially needing to host In-house apps for iOS.
We currently have an internal server running MySQL, Apache Tomcat. Consider this as a primary JSS. All internal network will communicate to this server based on DNS.
We have two DMZ JSS server boxes (load balanced) for any external devices. These are running Apache Tomcat and reporting into the internal server's MySQL.
We have a file share distribution point separate from JSS that houses all the macOS packages and scripts. This is only accessible via internal network.
We would like to put a distribution point in the DMZ for external device to access packages and host in-house iOS apps. I do not think we would like to have a file share distribution point using smb or afp to do this. I'm looking to run https distribution point. I see that the only option is to run JDS instance. Can anyone confirm this is the right direction to go and anyone have any experiencing setting this up?
Reference: http://docs.jamf.com/9.97/casper-suite/jss-install-guide-mac/About_Distribution_Points.html
