installing wazuh agents using jamf pro
  • November 22, 2023
  • 88 views
Hello Community,
I am trying to install wazuh agents in our organisation's computers in an effective way, and i wanted to use jamf pro for this.
Any one have an idea on how to do this? or any alternative way?
AJPinto
  • November 22, 2023
Im not familiar with this applications. However from the vendors documentation it looks pretty straight forward. You would put the vendors package in a policy with a cache Action it rather than installing it. Then write a script using their documentation to run the package, and start the agent. I would suggest reaching out to the vendor for assistance if needed.
Installing Wazuh agents on macOS endpoints - Wazuh agent
  • January 8, 2025
Hello,
Just curious if you were able to get this working? I need to do the same.
Thanks
