Posted on
05-30-2018
09:01 AM
- last edited
a month ago
by
kh-richa_mig
Hi, we are planning to rollout Intel Unite to share Mac screens to the display in meeting rooms.
Problem is that first launch it tries to install some AV components, none of the Application packaging tools are able to capture it.
Has anyone done it before? See attached screenshot for prompt.
Thanks in advance.
Posted on 06-14-2018 12:10 AM
I haven't found a good way to do it yet but here's a workaround:
After installing the AV tools on a machine, package /Library/Audio/Plug-Ins/HAL/ACE.driver with the following post-install.
/usr/sbin/chown -R root:wheel /Library/Audio/Plug-Ins/HAL/ACE.driver
/bin/ln -s ACE.driver /Library/Audio/Plug-Ins/HAL/InstantOn.driver
/Library/Audio/Plug-Ins/HAL/ACE.driver/Contents/Resources/acetool install
/usr/bin/killall -c coreaudiod -u _coreaudiod
defaults write /Library/Preferences/com.intel.Intel-Unite.plist AVMode -bool TRUE
defaults write /Library/Preferences/com.intel.Intel-Unite.plist AudioComponentsPromptedOnce -bool TRUE
Posted on 09-26-2019 01:01 AM
In the meantime Intel has released a version of Unite where this can be automated in a smoother way.
PATH="/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin"
echo "Starting Intel Unite audio driver installation..."
"/Applications/Intel Unite.app/Contents/MacOS/Intel Unite" -installaudiodriver 2>&1
Use this a postinstall script when creating your package with Composer.
