Posted on
04-03-2019
03:18 PM
- last edited
4 weeks ago
by
kh-richa_mig
Hi all,
I'm in the process of getting our legacy systems enroled into Jamf Pro and a number of them (around 10% at this stage) are getting an error "Device Enrolment" installation failed.
The MDM server for your organisation returned an unexpected status (403)
From a brief search it appears that deleting /Library/Keychains/apsd.keychain
and re-booting will fix the issue but given I want to enrol ~6-800 devices this way, actioning 10-15% of those by hand could be tedious.
Taking a look at the server logs I can see these entries which started occurring the same time as I kicked off the enrolment nag.
2019-04-03 05:45:01,290 [ERROR] [lina-exec-6] [dEnrollmentIssuerVerifier] - Unable to validate issuer
java.security.cert.CertPathBuilderException: Certification path could not be validated.
at org.bouncycastle.jce.provider.PKIXCertPathBuilderSpi.engineBuild(Unknown Source)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
at com.jamfsoftware.jss.utils.security.CloudEnrollmentIssuerVerifier.isIssuerValid(CloudEnrollmentIssuerVerifier.java:64)
at com.jamfsoftware.jss.utils.SecurityUtils.isIssuerValid(SecurityUtils.java:349)
at com.jamfsoftware.jss.utils.SecurityUtils.validateCMSSignature(SecurityUtils.java:272)
at com.jamfsoftware.jss.utils.SecurityUtils.verifySignatureForEnrollment(SecurityUtils.java:338)
at com.jamfsoftware.jss.frontend.enrollment.configurator.ConfiguratorEnrollmentStep.isSignatureLegit(ConfiguratorEnrollmentStep.java:160)
at com.jamfsoftware.jss.frontend.enrollment.cloud.DEPEnrollmentStep.shouldProcessStep(DEPEnrollmentStep.java:61)
at com.jamfsoftware.jss.frontend.enrollment.ota.OTAEnrollmentController.doProcess(OTAEnrollmentController.java:97)
at com.jamfsoftware.jss.frontend.enrollment.ota.OTAEnrollmentController.doPost(OTAEnrollmentController.java:75)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
at com.jamfsoftware.jss.frontend.streamlinedenrollment.CloudEnrollmentFilter.doFilter(CloudEnrollmentFilter.java:39)
at com.jamfsoftware.jss.frontend.JSSLoadingFilter.doFilter(JSSLoadingFilter.java:209)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:494)
at org.apache.catalina.valves.SemaphoreValve.invoke(SemaphoreValve.java:167)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.StuckThreadDetectionValve.invoke(StuckThreadDetectionValve.java:208)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:676)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1476)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.bouncycastle.jce.exception.ExtCertPathValidatorException: Could not validate certificate: certificate expired on 20180922043724GMT+00:00
at org.bouncycastle.jce.provider.RFC3280CertPathUtilities.processCertA(Unknown Source)
at org.bouncycastle.jce.provider.PKIXCertPathValidatorSpi.engineValidate(Unknown Source)
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292)
at org.bouncycastle.jce.provider.PKIXCertPathBuilderSpi.build(Unknown Source)
... 42 more
Caused by: java.security.cert.CertificateExpiredException: certificate expired on 20180922043724GMT+00:00
at org.bouncycastle.jce.provider.X509CertificateObject.checkValidity(Unknown Source)
... 46 more
2019-04-03 05:45:01,299 [WARN ] [lina-exec-6] [DEPEnrollmentStep ] - Processing device rejection: FAILED_SIGNATURE_CHECK
2019-04-03 05:45:01,299 [ERROR] [lina-exec-6] [onfiguratorEnrollmentStep] - Unable to process signature for enrollment request
I'm thinking this means there is a certificate inside apsd.keychain
which is expired and this is why the devices are having issue communicating. Does anyone know of a way to detect or get macOS to refresh these certificates without requiring a reboot? There (so far) doesn't appear to be any obvious combination of hardware, OS version or other software I can check against.
Also, is there a way to match up the above server log with an endpoint (IP address) - I'm running on jamfcloud otherwise I'd triangulate with the apache logs or other access logs but I don't think I have access to those.
New devices, fresh built devices, new OS installs and at least 85% of existing devices don't have an issue at all. Just seems to be a significant handful with the issue.
Posted on 04-03-2019 03:46 PM
security dump-keychain /Library/Keychains/apsd.keychain
gets me some info I might be able to check
update:
/usr/bin/security find-certificate -a -p -Z /Library/Keychains/apsd.keychain | /usr/bin/openssl x509 -noout -enddate| cut -f2 -d=
will get me the expiry date of the apsd certificate - if it's expired, then I can avoid initiating the DEP nag on that device
update 2:
The following script can be used to detect if the certificate in apsd.keychain is valid or not
KEYCHAIN="/Library/Keychains/apsd.keychain"
DATENOW=$(date "+%Y%m%d")
if [ -e ${KEYCHAIN} ]; then
CERTDATA=$(/usr/bin/security find-certificate -a -p -Z ${KEYCHAIN})
CERTEXPDATE=$(echo "${CERTDATA}" | /usr/bin/openssl x509 -noout -enddate| cut -f2 -d=)
CERTDATECMP=$(date -j -f "%b %d %T %Y %Z" "${CERTEXPDATE}" "+%Y%m%d")
echo "CERTDATA = ${CERTDATA}"
echo "CERTEXPDATE = ${CERTEXPDATE}"
echo "CERTDATECMP = ${CERTDATECMP}"
if [[ ${DATENOW} -ge ${CERTDATECMP} ]]; then
echo "apsd keychain certificate EXPIRED"
echo "apsd keychain certificate VALID"
echo "Could not find ${KEYCHAIN}"
Posted on 04-04-2019 04:39 PM
So thank you to Jesse Peterson over on slack for finding this
MDM spec here https://developer.apple.com/library/archive/documentation/NetworkingInternet/Conceptual/iPhoneOTAConfiguration/profile-service/profile-service.html#//apple_ref/doc/uid/TP40009505-CH2-SW4
with this little tidbit:
WARNING: When device certificates signed “Apple iPhone Device CA” are evaluated their validity dates should be ignored.
so Jamf is being good for checking certificate validity but is actually not following the MDM spec by doing so - also Apple for advising certificate validity checks should be ignored ಠ_ಠ
I'm pretty confident Apple aren't going to change and a bugfix from Jamf probably won't happen in time for me to continue the rollout, but, at least I know what's going on now so I can work around it.
