iOS 15.02 does not respect "Erase contents and settings" from Config Profile
Sandy
Valued Contributor II
ruh roh.
Anyone else notice this?
1 ACCEPTED SOLUTION
sdecook
Contributor
I believe this is fixed in the 15.1 betas. It is something on Apples end that was missed with the 15 update as others have stated.
6 REPLIES 6
christina_luis
Contributor
I was FORCED to update an iPad to iOS 15.0.2 when restoring from an iCloud backup.  I just looked and that option is available to this student iPad as well.  Hopefully they don't figure that out.
Sandy
Thanks for confirming...
I have had a few leak through to iOS 15 despite my restriction. This batch was purchased at start of COVID and I wanted to get them updated through Configurator instead of over the wifi....sadly configurator does not allow a choice of iOS versions....
Thats always a bummer, I think that is one thing that I like about Jamf is that it offers that.
rcorbin
Contributor II
The issue is known by Jamf. There is another thread ongoing about this :
https://community.jamf.com/t5/jamf-pro/ipados-15-gt-erase-all-content-and-settings/td-p/247908
It's supposedly an Apple issue with iOS 15. Its under  Jamf PI-010163
sdecook
Contributor
Sandy
Is it considered helpful to open a case with jamf for the PI?
Gives it more weight or anything?
