Posted on
06-04-2018
08:57 PM
- last edited on
03-04-2025
05:07 AM
by
kh-richa_mig
Is there a way for me to see the battery level ("current charge") for iOS devices? In my case I've got fully DEP supervised devices in Jamf Now, and I'm looking for a UI way to do it. If UI isn't possible, I'll use an API (but I have no idea if that's even possible... is there one for Jamf Now users?).
Solved! Go to Solution.
Posted on 06-09-2018 11:29 AM
Unfortunately I was wrong - I hadn't realized the post I found about battery level in Lost Mode was specifically looking at Jamf Pro (I don't think it actually specified... I can't find it now or I'd link). Anyway, in Pro you can get the level but in Now you cannot.
Posted on 06-04-2018 09:01 PM
Hmm... looks like it might be available in Lost Mode. Is there a way to get the data without Lost Mode?
Edit: sadly battery level is not present in Lost Mode for Jamf Now (this is one of the many subtle upgrades you get with Jamf Pro). I contacted support and they confirmed there is no way to remotely monitor battery level with Jamf Now.
Posted on 06-05-2018 12:19 AM
I'm not familiar with Jamf Now. In Jamf Pro the Battery Level is visible in the Inventory Tab under Hardware. I guess it is there in Jamf Now as well. Keep in mind that the Battery level is reported during inventory Updates which happen once every Day by default.
