IOS ScheduleOSUpdate does not work, Authorization failed
  • September 1, 2022
  • 12 views
Hello,
we try to update our Mobile devices via the API.
https://developer.jamf.com/jamf-pro/reference/createmobilescheduleosupdatecommandurl
https://yourServer.jamfcloud.com/JSSResource/mobiledevicecommands/command/ScheduleOSUpdate/{install_action}/id/{id_list}
nor
https://yourServer.jamfcloud.com/JSSResource/mobiledevicecommands/command/ScheduleOSUpdate/{install_action}/{product_version}/id/{id_list}
are working. We get a 401 with a restricted user or a full admin
Response:
HTTP/2 401
date: Thu, 01 Sep 2022 15:12:24 GMT
content-type: text/html;charset=UTF-8
content-length: 424
set-cookie: XYZ; Expires=Thu, 08 Sep 2022 15:12:24 GMT; Path=/
set-cookie: XYZ; Expires=Thu, 08 Sep 2022 15:12:24 GMT; Path=/; SameSite=None; Secure
server: Jamf Cloud Node
strict-transport-security: max-age=31536000; includeSubdomains;
x-frame-options: DENY
cache-control: no-store, no-cache, must-revalidate, max-age=0, post-check=0, pre-check=0
accept-ranges: bytes
x-xss-protection: 1; mode=block
strict-transport-security: max-age=31536000 ; includeSubDomains
set-cookie: APBALANCEID=aws.xxxx; path=/;HttpOnly;Secure;
anyone know a solution ?
1 reply
  • September 12, 2022
Below is the command I use.
/usr/bin/curl -X POST "$JSS_URL/api/v1/macos-managed-software-updates/send-updates" -H "accept: application/json" -H "Authorization: Bearer $JSS_TOKEN" -H "Content-Type: application/json" -d "{\\"deviceIds\\":[\\"$COMPUTER_ID\\"],\\"updateAction\\":\\"DOWNLOAD_AND_INSTALL\\",\\"forceRestart\\": true}" 2> /dev/null | /usr/bin/sed -nE 's/.*"id" : "([A-Za-z0-9\\-]+)",.*/\\1/p'
Note that:
$COMPUTER_ID is the device ID of the mac within the JSS.
$JSS_TOKEN is the bearer token for your JSS API account.
