iPad Re-Enrolment Problems
  • January 30, 2024
  • 138 views
Hello all,
I've been having quite a frustrating time trying to re-enroll one of our iPads to Jamf Pro recently and I feel like I've run out of thing to try so I'm hoping someone can lead me in the right direction or inspire a new way to try and get this thing running again. Heres whats going on and ill try to keep it brief:
- iPad at our organization was having trouble opening multiple apps (select app, would come up for a moment and crash).
- Tried multiple things to fix but no luck so I resorted to un-enrolling the device, wiping it and start from scratch.
- Tried to re-enroll the iPad via Apple Configurator 2 and have run into multiple errors Provisional enrollment failed. [MCCloudConfigErrorDomain - 0x80EF(33007)] being the most common.
- I've managed to re-enroll the iPad on our ASM but I'm hit with other errors now: "The configuration for your iPad could not be downloaded from organization ... cancelled" or in some cases a popup stating the iPad is not "supervised". (I have ensured when Preparing the device it is, in fact, being supervised).
- I've tried booting the device into the OS and downloading the MDM profile from the web browser and this also has not worked. (I've been hit with a contact your Administrator error).
As of right now I just can not get this thing to connect with Jamf and install the profile and have run out of options. Any guidance would be greatly appreciated.
Thank you
1 reply
  • September 27, 2024
I just started seeing this same issue.  Did you ever figure out a resolution?
