Having trouble with syncing iPads.
- Must have "allow installing apps" turned on in order to add new apps
- Using Casper I have created a profile that turns on "allow installing apps"
- Only one profile at a time can manage an individual or group of devices
- I have one master profile that sets ALL desired restrictions
- I disable the "ALL desired profile", then enable the one that "allows installing apps" that cannot happen because during the interim between profiles management the "individual iPad "Enable Restrictions" kicks in and won't allow changes in settings.
- If I disable restrictions and run the "All desired profile" unpredictable applications get turned on that I don't want to be turned on: iTunes, Ping, and "Allow delete apps".
- As long as any profile is managing an iPad(s) you are locked out of manually changing any settings
iPad syncing conflict when using Casper managerd Restrictions
