Is there a way to lock your network to a single SSID using a configuration profile?
  • November 15, 2023
  • 15 views
I would like to enforce being locked to a single Wi-Fi. The issue is, each device is going to be on a different network. Can I manually set up to lock each device to a single network I specify?
1 reply
cenforce
  • November 25, 2023
Hey @mspikes ! Enforcing a single Wi-Fi network for devices on different networks could be challenging due to the inherent variability. Instead of manually locking each device to a single network, consider leveraging Jamf's configuration profiles and Wi-Fi payload options. You might preconfigure Wi-Fi settings for each device, but keep in mind the practicality of enforcing this in diverse locations. Alternatively, explore the feasibility of a VPN or a global network solution to ensure connectivity while maintaining centralized control. Testing configurations in a controlled environment before widespread implementation is always a good practice!
