Is there a way to prevent a user from setting up Bootcamp?
Basically the title. We would like to prevent certain users from using Bootcamp on their Macs. I can't seem to figure out a way to prevent this. I know it sounds dumb but this is coming from above me, plus the thought of supporting 2 operating systems on one device doesn't sound fun.
Best answer by bpavlov
Remove admin access and Firmware password.
bpavlov
  • 1206 replies
  • April 16, 2018
  • 4 replies
  • April 16, 2018
You could add Boot Camp Assistant to Restricted Software.
richtea86
  • 23 replies
  • April 16, 2018
I would second the Firmware password option, that'll stop them from changing the startup volume.
  • 51 replies
  • April 16, 2018
@rich.thomas @bpavlov Yeah, I should have had the EFI PW to begin with, just created a policy for that. Thanks!
howie_isaacks
Forum|alt.badge.img+23
  • 773 replies
  • April 17, 2018
Like @jlramos said, just add the Bootcamp setup assistant to the restricted software list. That's what I did, and this makes it easy to scope exemptions for users who actually need to install Windows via Bootcamp.
ImAMacGuy
  • 1310 replies
  • July 3, 2019
The process name is
Boot Camp Assistant
boot camp assistant isn't required to create a bootcamp partition
Cookie policy
Cookie settings
