Posted on
06-30-2017
01:25 AM
- last edited
Tuesday
by
kh-richa_mig
Hi Guys,
Has any one seen this? We don't enroll many macs using the recon app so have not noticed this until now.
When trying to do a remote enrollment with recon we get the following error.
However i can scp over a quick add package and install it via ssh just fine.
Solved! Go to Solution.
Posted on 07-01-2017 03:38 AM
Solved my own issue. The admin account in question had a $ sign in the password.
Posted on 06-30-2017 03:00 AM
Hello stonham,
Try deleting the com.jamfsoftware.jamf.plist file from below location and start the re enroll process.
/Library/Preferences/
Hope it works!
Regards
Vijendra
Posted on 07-01-2017 03:04 AM
Hi @jamfvijju
Unfortunately that did not work.
rm /Library/Preferences/com.jamfsoftware.
rm ~/Library/Preferences/com.jamfsoftware.
killall cfprefsd
I even tried from another mac still now luck.
Ash
Posted on 07-01-2017 03:29 AM
I just enabled the root user on a test machine and tried enrolling as root and it worked.
Seems to just not work with standard admin accounts.
