Jamf connect no wifi.
  • January 31, 2025
  • 4 replies
  • 30 views
tdenton
where getting odd issues with Jamf connect at the start of our build procees not showing our wif network, it cant be seen at login screen but if you login local it leaps into action. Anyone else seen this before. Toggling button seems to make no difference.
  • January 31, 2025
  1. Have you enabled the following option in the Jamf Login Configuration Profile?
2. Which version of jamf connect you are currently using?
  • January 31, 2025
tdenton
  • February 3, 2025
2.43.0
tdenton
  • February 3, 2025
2.43.0
have network selection selected as well.
