Jamf Patching Extension Attribute Issue
  • March 13, 2025
  • 82 views
elsmith
Does anyone know of a way to modify the built-in extension attribute for a Patch Management title? The issue I'm seeing is that the one for Jamf Protect is pointing to /Library/Application Support but the application is installed in /Applications, meaning the extension attribute is turning up as blank for all the machines.
If there's no way to modify, is there at least a way to point the Patch Management version collection to a different place?
Any help is appreciated!
Best answer by sdagley
@elsmith Go to Settings->Computer management->Extension attributes and find the definition named jamf-patch-jamf-protect. You can open that definition and edit the path there.
That does trigger an error notice in the Patch Management panel for Jamf Protect because the EA has changed, but I don't know if that prevents any Patch policies from working.
sdagley
  • March 13, 2025
elsmith
  • March 13, 2025
THANK YOU!!! I will try that!
  • April 8, 2025
You’ll fix it, custom script should solve this easily!
