Jamf Pro 10.48 release
  • July 11, 2023
  • 9 views
PCalomeni
Hello Jamf Nation! You will find details about Jamf Pro 10.48, including the Cloud Upgrade Schedule and Release Notes Video, as well as all future versions in the new Jamf Release Info space.
  • July 20, 2023
WARNING if you are running Jamf Pro on Windows!  I installed last week and everything went like it does normally. Everything was working fine until we patched windows over the weekend, causing a reboot. On reboot, I got a database schema error. There is a PI for 10.48.0 for this PI112268.  I had to roll back to a snapshot.
  • July 21, 2023
The 10.48.1 release does not fix the database error on reboot.
