Jamf Pro EOL Question
Hello,
I did a bit of searching for this answer, but I wasn’t able to find anything as exact as what I’m looking for. I have a 100 something iPad 8th Gen’s. I keep getting told that they will no longer be supported in Jamf Pro around the fall of 2025. This is from someone internally in my company.
From what I’m seeing, it’s not necessarily 8th Gen’s that are no longer supported, it is devices that are not able to be updated to a certain iOS.
The way I understand it, as long as the device is not older that 4 major iOS versions, then it is supported. So in the Fall of 2025, as long as the device is iOS 16 or higher (assuming iOS 19 comes out), it is still supported. Am I correct on this?
Best answer by Shyamsundar
Yes it’s based on the iPad os version
kindly refer the minimum os requirement for Jamf 11.10 , its support still iOS 14
https://learn.jamf.com/en-US/bundle/jamf-pro-release-notes-current/page/System_Requirements.html.
Shyamsundar
  • 282 replies
  • October 13, 2024
AJPinto
  • 2708 replies
  • October 13, 2024
This is more to do with the version of iPadOS than it is the hardware model. Since Apple refuses to provide roadmaps of when they will stop supporting a given model, Jamf cannot provide a roadmap of when they will drop support for it.
Also keep in mind, you can still enroll unsupported OS’s but they may not behave as intended and the MDM commands that you issue with Jamf may not work on them.
  • October 13, 2024
Thanks for this all. When would be a good estimate of when the 8th Gen iPads would fall under unsupported?
Cookie policy
Cookie settings
