JAMF System Admin Tools using SwiftDialog GUI
  • June 6, 2025
  • 0 replies
  • 129 views
Hey All...just finished what I call the "JAMF System Admin Tools"...this SwiftDialog based app will backup your SS icons, System Scripts, Computer EAs, Make VCF cards from your email addresses, show (& clear) failed MDM commands and backup your configuration profiles! Been working on this for a while, and I think it is ready for the masses. I will be added more features and tweaking the logging in the next few weeks. Let me know if you run into any issue or any feedback you want to give!
(I combined my failed MDM commands, SS Backup and VCF Cards standalone apps into one).  More coming soon...
The following items are available to be backed up:
  1. Self Service Icons - Great to have a back when JAMF starts showing generic icons in Self Service.
  2. Failed MDM Commands - Export systems that have failed MDM commands so you can review them and optionally clear the failures
  3. System Scripts - Everything that is stored in Settings > Scripts
  4. Computer Extension Attributes - Export all of the computer extension attributes
  5. Configuration Profiles - Export all of the configuration profiles to .mobileconfig files
  6. Export Emails to VCF - Export all of the email addresses to a VCF file, which can be imported into Contacts.app or other applications.
This script is fully multitasked, so will execute each task pretty quickly. It will create the folder structure for you and then download the items to the appropriate folders.
File Formats
  1. Icons have a .png extension.
  2. Scripts have a .sh extension.
  3. Computer Extension Attributes have a .sh extension.
  4. Configuration Profiles have a .mobileconfig extension.
  5. Emails have a .vcf extension.
Repo: https://github.com/ScottEKendall/JAMF-Pro-Scripts/tree/main/JAMFSystemUtilities
