Jamf Variables ($BUILDING, $ROOM) as Script Parameters ($4, $5)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
03-04-2020
08:11 AM
- last edited on
03-04-2025
05:36 AM
by
kh-richa_mig
I'm looking to create a hostname renaming script for Macbooks deployed across various buildings and sites, and I was thinking I'd be able to use the variables from Jamf to define part of the hostname.
Setting the parameter as $BUILDING doesn't seem to work, it just passes through as "$BUILDING". Is there a way to make this work, or will I have to create a separate profile for each site and assign them to the appropriate Jamf group?
- Labels:
Configuration Profiles
Scripts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-18-2020 04:48 AM
I would like to do something very similar but running into the same issues. Do the variables as described here (https://docs.jamf.com/10.21.0/jamf-pro/administrator-guide/Computer_Configuration_Profiles.html) only work in config-profiles and not as input for policy-scripts?
I am trying to use $DEPARTMENTNAME, $ROOM and $FULLNAME
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-22-2020 06:22 AM
I think that this can be done, but not too easly, as it involves using the API.
I have used the following script a few times. It sets the name to the asset tag. It could be easily adapted to use the Room or Department or any other value.
Of course, it requires you to set up an API User with privs to read computer objects.
Here is the script:
# vars
SERIAL_NUMBER=$(ioreg -c IOPlatformExpertDevice -d 2 | awk -F" '/IOPlatformSerialNumber/{print $(NF-1)}')
JSS="https://my_server.jamfcloud.com"
API_USER="$4"
API_PASS="$5"
ASSET_TAG_INFO=$(curl -k $JSS/JSSResource/computers/serialnumber/$SERIAL_NUMBER --user $API_USER:$API_PASS | xmllint --format --xpath '/computer/general/asset_tag/text()' -)
SUFFIX=""
if [ -n "$ASSET_TAG_INFO" ]; then
echo "Processing new name for this client..."
echo "Changing name..."
jamf -setComputerName -name "$ASSET_TAG_INFO"$SUFFIX
echo "Name change complete. ("$ASSET_TAG_INFO"$SUFFIX)"
echo "Asset Tag information was unavailable. Using Serial Number instead."
echo "Changing Name..."
jamf -setComputerName -name $SERIAL_NUMBER$SUFFIX
echo "Name Change Complete ($SERIAL_NUMBER$SUFFIX)"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-28-2020 01:24 AM
Great, below is what I made of it.
In general this works great but "jamf setComputerName -name" doesn't set the .local-name on my Macs.
#!/bin/zsh
local SERIAL_NUMBER
local JSS
local API_USER
local API_PASS
local MODELNAME
local DEPARTMENT
local DEVICE
local ROOM
local NAME
local MAC_NAME
# vars
MODELNAME=$(system_profiler SPHardwareDataType | grep "Model Name" | awk -F ': ' {'print $2'})
if [[ -n $4 ]] ; then
JSS="$4"
echo "Jamf-URL not set."
exit 1
if [[ -n $5 ]] ; then
API_USER="$5"
echo "API-User not set."
exit 1
if [[ -n $6 ]] ; then
API_PASS="$6"
echo "API-Password not set."
exit 1
case $MODELNAME in
*Pro*)
DEVICE="MB Pro"
*Air*)
DEVICE="MB Air"
*mini*)
DEVICE="Mac mini"
*iMac*)
DEVICE="iMac"
DEVICE="unknownMac"
esac
DEPARTMENT=$(curl -k $JSS/JSSResource/computers/serialnumber/$SERIAL_NUMBER --user $API_USER:$API_PASS | xmllint --format --xpath '/computer/location/department/text()' -)
ROOM=$(curl -k $JSS/JSSResource/computers/serialnumber/$SERIAL_NUMBER --user $API_USER:$API_PASS | xmllint --format --xpath '/computer/location/room/text()' -)
NAME=$(curl -k $JSS/JSSResource/computers/serialnumber/$SERIAL_NUMBER --user $API_USER:$API_PASS | xmllint --format --xpath '/computer/location/username/text()' -)
NAME=$(echo $NAME | awk -F '.' '{print $1 " " $2}' | awk 'NF>1{print $NF}')
NAME=${(C)NAME}
MAC_NAME=$DEPARTMENT" "$DEVICE" "$ROOM" ("$NAME")"
jamf setComputerName -name $MAC_NAME
sleep 1
jamf recon
