Jamf wifi profile not working using auto join
  • May 9, 2023
  • 0 replies
  • 11 views
We have a configuration profile configured in Jamf Pro. Config is set to auto join users using PEAP and radius authentication with a saved generic AD username and password. When applied the associated ipads fail to auto join. If you then remove the config profile from the ipad, you are then able to connect manually adding the username and password (or any other AD user account) to the wifi SSID on the iPad. We are using Meraki access points for WIFI config.
