Jamfnation forum interprets code in scripts incorrectly
  • August 18, 2021
  • 4 replies
  • 44 views
atomczynski11
Hello,
Seems that Jamfnation pages now interpret code in messages incorrectly as described in this page.
https://community.jamf.com/t5/jamf-pro/best-way-to-demote-user-from-local-admin-to-standard-on/td-p/154332
The page converts code into emojis.
This should be turned off for text entered as code.
Is this possible that this happened after the forum conversion?
As an example if I type the following two characters : / together I see this: 😕😕
Even in code:
Perhaps it needs to be change how it's interpreted from HTML to something else...
Best answer by CalleyO
Thanks, @atomczynski11, and @ljcacioppo for bringing this to our attention. You should no longer run into this issue, but please reach out if you do.
ljcacioppo
  • August 18, 2021
CalleyO
Forum|alt.badge.img+15
  • Employee
  • August 18, 2021
ljcacioppo
  • January 13, 2022
Just had this happen again in my reply here: https://community.jamf.com/t5/jamf-pro/best-user-detection-command-for-scripts/td-p/256015
CalleyO
  • Employee
  • January 13, 2022
Thanks, Leo, for bringing this to my attention. I'm on the case!
