JSS not allowing traffic from a certain SSID
  • October 10, 2014
  • 17 views
I've got a help desk request going on with this but thought I would throw it out to the masses as well.
My JSS is allowing traffic from one SSID and not another (which is of course the one that the iPads need to be on and are configured to do so automatically). When connected to any device on that bad SSID, I am not able to connect to the JSS. If I create a new SSID or use a different one, I can connect right up. Any ideas with this one?
Forum|alt.badge.img+23
  • October 10, 2014
It probably won't be the JSS.
Get a hold of this app and put it on a test iPad. http://www.amsys.co.uk/2013/blog/amsyss-services-test-iphone-app/
See if that reports if the correct address and ports are open.
emily
  • October 10, 2014
Sounds like a firewall issue. Do you have a Network Engineering team to talk to about it?
  • October 13, 2014
You could do some initial testing using; ( from a workstation on that network )
nslookup jsshostname
DeathStar:~ D4$ nslookup chewbacca
Server:     10.34.24.41
Address:    10.34.24.41#53
Address: 10.105.216.99
traceroute jsshostname or ip
DeathStar:~ D4$ traceroute 10.105.216.99
traceroute to 10.105.216.99 (10.105.216.99), 64 hops max, 52 byte packets
 1  10.105.210.1 (10.105.210.1)  2.037 ms  2.414 ms  1.724 ms
 2  chewbacca.cenet.edu (10.105.216.99)  0.663 ms  0.653 ms  0.413 ms
telnet jsshostname 8443
DeathStar:~ D4$ telnet chewbacca 8443
Trying 10.105.216.99...
Connected to chewbacca.cenet.edu.
Escape character is '^]'.
Above results are from a working setup
