Posted on 09-20-2012 08:31 AM
I went to print this page and it's missing...did a search and came up dry...
Creating Minimal Base OS Images for Restore or NetBoot/NetInstall Imaging
https://jamfnation.jamfsoftware.com/article.html?id=63
Solved! Go to Solution.
Posted on 09-20-2012 08:49 AM
Hi Don,
We removed this article, along with the article on creating NetBoot images using System Image Utility. We've replaced them with this article:
https://jamfnation.jamfsoftware.com/article.html?id=307
This one should be more up-to-date and less confusing. We would've just kept the same article ID, but it got a little complicated since we combined two existing articles.
Thanks,
Erin
Posted on 09-20-2012 01:15 PM
There's a section in the Casper Suite Administrator's Guide called "Building OS Packages" that should do the trick for that. Nothing has changed for Mountain Lion.
Hi Don,
Thanks,
Erin
Posted on 09-20-2012 09:04 AM
Awesome thanks! :D
Posted on 09-20-2012 09:12 AM
I spoke too soon...article 307 is missing the steps for making Minimal Base OS Images. I have the old one printed out, but wasn't sure if there were any changes now that Mountain Lion is out.
Posted on 09-20-2012 05:29 PM
I think KB article 63 was a whole lot better than the steps in the PDF...but it's something. :) Good thing I have KB article 63 printed out. I'll create an in house document modeled after it. Off to make lemonade...LOL
Thanks,
Don
Posted on 09-21-2012 12:34 PM
I also referenced the old KBs and would appreciate if something similar was put back online.
Posted on 10-08-2012 10:09 AM
donmontalvo or anyone else who has the article would you be able to send it to me? There was an especially helpful comment on that article that included a script to slim down an OS that I haven't been able to find anywhere else.
Posted on 11-14-2012 10:16 AM
Hey everyone,
Back by popular demand is an article that walks you through the entire process for installing a clean copy of OS X, configuring the OS, and building a package of the OS. It is available here:
Creating a Minimal Base OS Image
Hopefully both this article and the Creating NetBoot Images for Use with the Casper Suite article are clearer and more helpful than they were in the past.
Thanks for your patience!
Erin
