Kerberos SSO default realm issue
  • September 25, 2020
  • 10 replies
  • 256 views
Hi Everyone,
Wondering if anyone has recently experienced an issue with Apple Kerberos SSO for macOS not recognizing the default realm set in the Jamf config profile?
I have been testing this in advance of replacing enterprise connect, and had it set up and working perfectly with our single domain, got everything working how I wanted it, live password testing etc, and had several test users reset their password successfully.
Now this week when I went to change my own password, I got the message in the screenshot. Nothing in the config profile has changed, has anyone seen this or have any suggestions?
all clients are on Catalina latest version
Best answer by Jason33
Yes, I ran into this in July. You have to create a file called krb5.conf and place it in /etc. The content of the file should look like this:
[libdefaults]
default_realm=YOUR.REALM.NAME
Package that up in Composer and deploy to your machines that have the kerberos extension enabled.
Jason33
[libdefaults]
thanks for the quick response, I will try that right now! did you find info via support from apple or jamf or something? There is nothing like that in any of the documentation :(
Jason33
Apple Support. Apparently the fix will be released with Big Sur.
  • September 30, 2020
@Jason33 I wish there was a dislike button... That is NOT the way. Not your fault, I know, but discouraging that so many of Apple's solutions today are just "(complete a major) upgrade to the next thing" rather than using their the barest sliver of their profitability to fix bugs and issues for older versions.
Jason33
@Sterritt I completely agree. Not everyone is going to upgrade to the next major release, and certainly not businesses will jump on it right away. This should be fixed by Apple in Catalina, no question.
  • November 2, 2020
Just found this. I tried this solution, but i'm still getting this error. using Jamf Connect 2.0.1 on 10.15.7
  • November 2, 2020
Nevermind, I think I had an error in my krb5.conf file. :facepalm: re-did it all and it worked.
MikaelDez
  • May 28, 2021
@Jason33 I just tried this, packaged it with Composer and I still get the default realm is missing. Laptop is on Catalina because my Comm Media professors are adamantly refusing Big Sur for software compatibility - any ideas?
Thanks,
Mike
  • July 20, 2021
To save time and for deployment speed I scripted it instead of making a package. No composer work needed. Also if Jamf Connect is already running then it would seem like the fix is not working @MikaelDez you will need to "quite" Jamf Connect or better yet unload it first. So the full solution is below.
#!/bin/bash #Find the Current users ID. currentUser=$( /usr/bin/stat -f %Su "/dev/console" ) userID=$( /usr/bin/id -u "$currentUser" ) #Unload the Jamf Connect Menu bar app /bin/launchctl bootout gui/"$userID" /Library/LaunchAgents/com.jamf.connect.plist #Create the Kerberos file touch /etc/krb5.conf #Write the content into the file cat << 'EOT' >/etc/krb5.conf [libdefaults] default_realm=MCSLTD.INTERNAL EOT #wait 2 seconds sleep 2 #Kill any running instance with the name Jamf Connect pkill "Jamf Connect" #Re-launch Jamf Connect Menu bar app (by launching the LaunchAgent) /bin/launchctl bootstrap gui/"$userID" /Library/LaunchAgents/com.jamf.connect.plist exit 0
MrRoboto
  • November 4, 2021
This worked great, thanks!
