LaunchAgent/Deamon - Script for starting jamf selfservice policy for user
  • September 1, 2023
  • 106 views
Jacek_ADC
Hello Nation
I started to optimize a few things in our PreStages. Better said, i started with testing for our new PreStage.
Following problem for me:
After my prestage with jamf connect notify script (wich installs everyhing an user need) I need to start instantly after the desktop appears to user the device compliance registration steps for the user.
In the past I have done this normally with a script and a policy which runs after the macbook is enrolled. The problem with this is that in most cases the script do not start always after the desktop appears. Although not with the login trigger in the policy.
So my first idea was to do exactly the same but with an launchagent or deamon. So i created a package with an LaunchAgent which should run the script atload. This works fine, but the script doesnt do all the steps.
Because I want keep everything small, I decided to create the launchagent which open only the selfservice policy at load. I dont know why, but this doent really looks that it is working. I am not such experienced scripting jamf user but started now with a few things after my passed jamf 300 course.
So the device compliance policy can be started automatically but the registration must be done through the user himself
This is like my LaunchAgent looks like:
The LaunchAgent is stored in /Library/LaunchAgents -> The Launch Agent will be removed in a following policy after the user had registered the device compliance.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>Label</key> <string>org.######.jamfselfservice.start.compliance</string> <key>ProgramArguments</key> <array> <string>/usr/bin/open</string> <string>\\"jamfselfservice://content?entity=policy&id=658&action=view"\\</string> </array> <key>RunAtLoad</key> <true/> </dict> </plist>
Here is the script i tried as first. This one will be started also with an launchagent:
LaunchAgent:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>Label</key> <string>org.#####.jamfselfservice.start.compliance</string> <key>ProgramArguments</key> <array> <string>/bin/bash</string> <string>/Library/Scripts/DeviceComplianceRegistration.sh</string> </array> <key>RunAtLoad</key> <true/> </dict> </plist>
This is the script:
#!/bin/bash sleep 10 echo > /var/log/DeviceComplianceRegistration.log # Define Variables brandIcon="/usr/local/V2ConstantLogos/logo_claim_anmeldung.png" policyID="658" #get logged in user loggedInUser=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' ) answer=$( osascript << EOF button returned of (display dialog "Please finish setting up your computer by running the Device Compliance Registration policy in Self Service. Click OK to get started!" buttons {"OK"} default button 1 with icon POSIX file "$brandIcon") EOF ) echo "$answer" if [[ $answer -eq "OK" ]]; then su "$loggedInUser" -c "killall Self\\ Service" su "$loggedInUser" -c "open \\"jamfselfservice://content?entity=policy&id=$policyID&action=view\\"" fi /usr/local/bin/jamf manage #sudo jamf recon exit 0
I like to deploy this directly with the prestage as pkg.
 I appreciate for any ideas how to go further with this.
  • September 1, 2023
Instead of using
for the commands that need to run as the user, try using the method Armin Briegel outlines in his post here: https://scriptingosx.com/2020/08/running-a-command-as-another-user/
You may get better results. I use this method almost exclusively when I need run something from a root run script as the logged in user.
Jacek_ADC
  • September 5, 2023
Thank you, i know this post, but forget about that. Will give a try.
