Legacy Definitions Patch management
  • April 16, 2021
  • 33 views
So I just today deleted the (legacy definitions) for Slack and Zoom in patch management. But the new ones are not populating at all. I also switched to the new definition for Firefox and chrome. Those are working properly. Has anyone seen that issue should I just go back to the legacy definitions?
Best answer by Matt_Ellis
So it turns out, my JAMF Cloud instance had a database issue with PM. if you're seeing there same contact JAMF they fixed it for me.
lilylily
  • April 21, 2021
I just noticed this issue in my dashboard as well and would love an answer to it!
  • April 21, 2021
