Posted on 04-08-2008 04:34 PM
How can I leverage netboot and casper to upgrade my people to leopard? And
keep their user profile ad binding etc intact?
Netboot and then create a dmg of a leopard disk? Expand it. Do an os
upgrade?
I don't want to do a rip and riimage.
Anyone manage that.
Or even a selfservice mode? Scary but useful!
sent via a blackberry
Posted on 04-09-2008 08:24 AM
Hello,
I would strongly urge you to consider doing fresh installs for a major OS
upgrade. Its a good standard practice as you probably don't want to bring
your Tiger baggage to the Leopard party.
If you're set on doing upgrades, you could use Netboot/Netinstall to perform
the upgrades.
If you are ok with wiping the system, here's how I would approach it using
Casper.
1. Add a script to your JSS that deletes everything on the target boot drive
except /Users. (You may also want to rename all users' Library folders to
Library.tiger to avoid potential conflicts. By renaming rather than
deleting, you or your clients can copy necessary items back into their new
library folders.)
2. Create autorun data for your target machine(s) containing your Leopard
configuration and the above script as a 'before' item. DO NOT check the box
to erase the target drive.
3. Boot target machines from an external, internal or netboot
restore/utility partition (not the target drive), log in as root and run
Casper.
You can use Casper's built in AD binding feature to bind to Active
Directory. I use a dscl script to bind to Open Directory, and a similar
script can be used for other directory services.
I hope this helps.
Miles Leacy
Senior Macintosh Technician
Polo Ralph Lauren
212-318-7603
miles.leacy at poloralphlauren.com
