HI all,
I have a configuration profile to set the login window preferences. It seems to be pushing down to all 24 machines but the option for Automatic Login is not sticking on 12 of those machines. If I go to the login window preferences on that machine, the box is unchecked to auto log in. If I log out of those machines manually I see that the profile is there because the message above the login prompt I want is there. But when I restart, they auto login as the admin user.
I've deleted the profile and recreated it but those same machines still auto login. I've seen the other posts but have not seen a clear reason as to why this is happening or a clear fix for it. Any help would be greatly appreciated.
I have the level set to Computer Level
Using JSS 9.32 and the clients are 10.94
Thanks in advance
Pete
