Loom in Patch Management not showing most recent definitions
  • August 21, 2023
  • 11 views
Loom is only showing up to version 0.168.1 in the Patch Management definitions, however Loom on the machine that I use to create packages has updated to 0.169.3.  Since 0.169.3 isn't an option in Patch Management I'm unable to associate a new package to update the rest of the machines.  Can someone update the definitions that are available for Loom?
Thanks In Advance
Best answer by ahilla
I see that 0.169.5 has been updated in Patch Management, not sure why 0.169.3 was skipped but I'm moving on to the newer version now.
Thank You
1 reply
  • August 22, 2023
Thank You
