Lost lock code
tomaszgruszka
New Contributor II
We've locked the computer with Jamf Pro and unmanaged it without backing up the lock code. After few weeks all the completed commands disappeared :(
Is there anything that can be done to unlock the laptop?
1 ACCEPTED SOLUTION
Tribruin
Valued Contributor II
If it as Apple Silicon, you can do a DFU restore to remove the code as well.
3 REPLIES 3
AJPinto
Honored Contributor III
You will need to contact Apple. They can bypass the remote lock. Be ready to provide ownership documentation for the device.
Tribruin
Amazing. It worked. Thank you very much
