Hi, I really appreciate Jamfs Patch catalog to grow but I have some Applications like LibreOffice and QGIS we are using struggling in real use.
We are using the "stable" or "LTR" releases of these Apps and the latest Versions of these LTS-Version don't show up in Jamfs Version definitions.
For example LibreOffice: the latest stable Version is 7.0.6 while Jamf Patch definitions jump from 7.0.4.2 to 7.1.0.1 wich is the non-stable version of LibreOffice.
Same with QGIS: the latest stable Version is 3.16.9 while Jamf Patch definitions jump from 3.16.3 to 3.18.0 wich is the non-stable version of QGIS.
Is there a way I can manually add version definitions?
