Posted on β02-18-2021 05:07 AM
Hello Everyone,
Im testing out a mac mini M1 with big sur 11.2.1 for the first time and i noticed something new happening which i never saw before with my Intel mac mini's (Running both Catalina and Big Sur).
As soon as i enroll the mac mini, manually, into my Jamf Pro instance im getting disconnected from ARD, only SSH works, and the Preference Pane for Remote Management now show's a new message that "Screen Sharing is managed", and i cant connect anymore to Remote Management.
Has anyone tackled this issue before?
I did open a case with Jamf but im trying to see if anyone has seen this happen before and maybe can give me a solution.
Im attaching screenshots.
Thanks in advance.
Solved! Go to Solution.
Posted on β12-13-2021 08:40 AM
It's not a problem till I install the workstation/laptop JAMF Profile Management Profile. Then all goes to hell.
I did find an article which is a work around, but for me...it's been a hit or miss fix.
Posted on β08-10-2021 07:27 AM
Hi - did you ever get this problem solved?
Posted on β07-09-2022 07:59 AM
Hi Mikey,
Could you share me that article?
Posted on β11-22-2021 11:47 AM
I have the same issue no idea whats causing it
