macOS Big Sur 11.0.1 Installer Issue
  • November 13, 2020
  • 21 views
CSCC-JS
Anyone getting the issue it just bounces in the dock then stops? It shows it’s still running under force quit, but the installerGUI never loads.
I was able to get it to install via terminal. It downloaded officially from software update.
Note this is an older 2014 MacBook Air, 4 GB ram, on a 256 SSD. I suspect age of hardware may be a factor.
Forum|alt.badge.img+21
  • November 13, 2020
https://www.theverge.com/2020/11/12/21563092/apple-mac-apps-load-slow-big-sur-downloads-outage-down-issues
MLBZ521
  • November 13, 2020
Either what tkimpton posted above or https://babodee.wordpress.com/2020/11/05/waiting-for-the-macos-big-sur-installer-to-launch/ could have something to do with what you're seeing.
