Managed Preference Profiles not applying to Network users?
Poseiden951
Contributor
Hello JAMF,
Testing out OS X Yosemite and wanted to set Safari Managed Preferences. It worked on 10.9.5 but not on 10.10.2 or 10.10.3.
Local admin accounts:
New windows open with: Homepage
New tabs open with: Homepage
Homepage: doman.edu
Network users:
New windows open with: Favorites
New tabs open with: Favorites
Homepage: domain.edu
In the managed profile I have:
com.apple.Safari NewWindowBehavior = 0
com.apple.Safari NewTabBehavior = 0
0 = show home page
Is this an issue with Yosemite?
Edit:
as an added bonus, this doesn't work in 10.10.3.
Disable Saved State:
Level at which to apply the preference. User-level-every-login
com.apple.loginwindow TALLogoutSavesState = 0
2 ACCEPTED SOLUTIONS
bentoms
Esteemed Contributor
@Poseiden951 There are a few threads on this.
TL:DR User Level Managed Preferences don't work on Yoyo.
Poseiden951
Contributor
@bentoms
Sigh, that sucks. I'll just use default, I'll have to test it out tomorrow.
Set new Safari windows to open to homepage
defaults write com.apple.Safari NewWindowBehavior -int 0
Set new Safari tabs to open to homepage
defaults write com.apple.Safari NewTabBehavior -int 0
edit:
Borrowed from rtrouton, thanks rtrouton!
Disable the save window state at logout
/usr/bin/defaults write com.apple.loginwindow 'TALLogoutSavesState' -bool false
2 REPLIES 2
bentoms
Poseiden951
Contributor
@bentoms
edit:
