.metadata_never_index added to boot volume by casper imaging
  • August 21, 2012
  • 28 views
I was puzzled as to why spotlight no longer worked on newly imaged machines.
After a little digging I found that they all had a .metadata_never_index file at the base of the root directory.
This file is put on the disk after imaging during the "Set Name to xxxxx" task.
Has anyone got any ideas why this might be happening? Currently working around this by scripting the removal of this file at first boot.
Cheers
Matt
Best answer by rlandgraf
It is a bug with 8.6 that JAMF is aware of here is a link to another discussion about the same problem. Hope this helps.
https://jamfnation.jamfsoftware.com/discussion.html?id=4939
  • August 21, 2012
  • August 21, 2012
Ahh thanks, my search didn't bring that up. I'll adjust my work around and wait for the fix.
cheers
Matt
  • January 25, 2013
Thanks for sharing, I was puzzled by this one yesterday as well :)
