MFA solution?
  • July 11, 2024
  • 4 views
Hello everyone!
We currently use DUO MFA for our 2nd way to authorize who you are, the first being your password. DUO MFA has glitched too many times and it is NOT JAMF, and not Apple MacBook Pros running Sonoma 14 fault.
I am wondering what MFA products are you using, if any.
I am also wondering if there is a script out there that forces the user to use the fingerprint reader after they enter their password which would suffice MFA?
If yes, I could dump DUO MFA program for once and all. When I reached out to DUO Tech support about the app glitches, you wouldn't believe the steps the end user has to take to get past DHO MFA. The steps are not for novice Mac users at all.
Any suggestions greatly appreciated as always.
1 reply
easyedc
  • 624 replies
  • July 12, 2024
What do you use for your account management? We're a Microsoft shop and as such use MSFT's authenticator.  It's been the app of choice for the last 2 (large windows deployment) organizations I've worked for and been fairly reliable.
Cookie policy
Cookie settings
