Mobile Device Enrollment Invitations- Failed to Send Invitation
  • October 12, 2017
  • 8 replies
  • 161 views
We are attempting to create an enrollment invitation to connect a few iPads purchased outside of our DEP agreement, but every attempt ends in failure. The result is always "There was 1 error sending invitation" with the status "Failed to send invitation". History doesn't show anything. Some previous posts direct to a resend option but I cannot find it. Anyone else having this issue?
Best answer by Tolandese
I solved it very recently and forgot about this thread. I had to update our SMTP server settings as we had an old email server we deprecated a few years back still listed for communications.
  • December 11, 2017
Did you receive a fix for this? I am experiencing the same issue
  • December 12, 2017
  • February 27, 2019
So, I'm still getting this error in sending invitations in late February 2019. It will work for a few days and then suddenly they will fail to send - repeatedly. Also, I can go to the SMTP settings and send myself a test email and it works fine every time. So, what's going on with the sending of invitations? Why the sporadic issue? Thanks for any help or ideas you can offer.
  • February 28, 2019
Having the same issue here with Jamf Pro. Can't figure out why. Tests also work.
  • July 17, 2019
Having the same issue as well, also test works. Anyone know why?
  • August 19, 2019
We are having the same issue. Any suggestions for a work around? Is there a URL we can send to the end users for enrollment?
  • October 24, 2019
This issue started for me today. Any updates?
  • October 14, 2020
Hi community,
I have the same issue.
I had to send about 20 invitations. The receiptients where separated with a linebreak (in the mask, there is a hint that the receiptients have to be separated by a linebreak od a comma). Every time, I am sending the invitations only 5 receiptients are successfull, the other ones failed.
Is it possible, that there is a limitation to 5 mails to send ?
Hope, someone can help me.
Thanks for answering and stay healthy,
NOVELLUS
EDIT:
solved:
we had internal a limitation to five receiptiens on our exchange server. After deleteing the limitation, all the receiptients are sucessfull
