12-13-2021 02:55 AM - edited 12-13-2021 06:11 AM
Model populates the Model Identifier value instead of Model for M1 Pro and M1 Max MacBook Pros. The M1 and Intel devices inventory shows the Model like "MacBook Air (M1, 2020), MacBook Pro (15-inch, 2018) etc.
We are running Jamf Pro 10.34.1.
Is this a bug or known issue ?
Thanks & Regards,
Karthikeyan
Posted on 12-13-2021 06:08 AM
@karthikeyan_mac This is normal until your Jamf Pro version is one updated to recognize the new models.
Posted on 12-13-2021 06:12 AM
@sdagley I missed mentioning the Jamf Pro version in the post. Edited it now.
We are running the latest version (10.34.1) of Jamf Pro.
Posted on 12-13-2021 06:23 AM
@karthikeyan_mac Updating Model IDs in Jamf Pro seems to be a low priority for updates, so it's not surprising 10.34.1 hasn't been updated (I believe the only change from 10.34.0 was the CVE-2021-44228 fix). It's likely 10.35.0 will recognize those models.
Posted on 12-22-2021 03:31 AM
Thank you. I added the extension attribute to fetch the information.
Posted on 12-22-2021 03:32 AM
Extension Attribute to fetch the Hardware Model.
cpuArch=`arch`
if [[ $cpuArch == "i386" ]]; then
model=$(curl -s https://support-sp.apple.com/sp/product?cc=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}' | cut -c 9-) | sed 's|.*<configCode>\(.*\)</configCode>.*|\1|')
elif [[ $cpuArch == *"arm64"* ]]; then
model=$(/usr/libexec/PlistBuddy -c 'Print 0:product-name' /dev/stdin <<< "$(ioreg -arc IOPlatformDevice -k product-name)" 2> /dev/null)
echo "<result>$model</result>"
12-23-2021 10:23 AM - edited 12-23-2021 10:34 AM
(never mind, misunderstood the question)
Posted on 03-24-2022 12:43 PM
Jamf Inventory shows wrong year for various models. "About this Mac" show 2017, which is correct. Jamf Pro show it as 2015 model? IDK
Posted on 03-24-2022 12:58 PM
@jttavares I believe Jamf Pro just goes by the Model Identifier, which Apple has been known to re-use occasionally. About This Mac may use a more precise method of acquiring the model name.
