Modify loginwindow wireless timeouts?
  • October 17, 2012
  • 2 views
Is there any way to change the timeout value for 10.8 loginwindow configuration profiles attempting to connect to directory-based wireless networks on login?
Seeing long delays on logins when connection to our WPA2E network at login fails to authenticate, which is usually seen in a 169.x IP address within 10 seconds of entering credentials.
Ideally we could simply timeout faster than what appears to be the current minimum 120 second timeout, since the machines do generally auth just fine at next login.
Cliff
FWIW, here's the console dump:
Oct 16 09:10:50 us-mac-6147-foo.com eapolclient[38206]: System Mode can't find AD account information
Oct 16 09:10:50 us-mac-6147-foo.com eapolclient[38206]: No user name provided, user interaction not allowed
Oct 16 09:10:58 us-mac-6147-foo.com configd[16]: network changed: v4(en0:10.102.80.112, en1-:169.254.215.78) DNS* Proxy SMB
Oct 16 09:11:17 us-mac-6147-foo.com configd[16]: network changed: v4(en0:10.102.80.112, en1+:169.254.147.221) DNS Proxy SMB
Oct 16 09:11:17 us-mac-6147-foo.com UserEventAgent[11]: Captive: en1: Not probing 'BCWIFI' (protected network)
Oct 16 09:11:17 us-mac-6147-foo.com configd[16]: network changed: v4(en0:10.102.80.112, en1) DNS Proxy SMB
1 reply
  • October 10, 2013
Hey Clif;
have the same issue , were you able to find a solution
tia
LS
