Posted on
07-03-2018
05:25 AM
- last edited
a month ago
by
kh-richa_mig
Hi All,
As we all know, Mojave is a beta, so there will be compatibility issues.
Just wondering if anyone with Mojave installed on their Mac is able to launch the Jamf Pro apps? They all crash immediately on my MBP.
Thanks for all input and be well,
C
Solved! Go to Solution.
Posted on 07-09-2018 09:56 AM
Hi All,
Update: I updated to the 10.14 Beta (18A326h), and Remote is now working normally.
C
Posted on 07-03-2018 05:52 AM
I was just able to run jamf admin without any crashing. I'm on beta 2 18a314h
Posted on 07-03-2018 06:20 AM
I am running 10.14 Beta (18A314k).
I actually tried all of the apps again, and they all work except Imaging and Remote. Sorry for the misdirection.
C
Posted on 07-03-2018 10:18 AM
Self Service working yet?
Posted on 07-03-2018 10:57 AM
No self service isn't working yet. I heard it was going to fixed in 10.6
Posted on 07-09-2018 08:25 AM
Ditto, I'm on 18A314k and Remote still crashes.
Posted on 07-09-2018 08:26 AM
@nvandam It tries to load and does nothing, but the dock icon shows the white dot showing it "launched".
Hi All,
C
Posted on 07-17-2018 04:22 PM
Cough...cough...combo updaters work now...cough...cough...
Posted on 07-20-2018 08:17 AM
I'm running 10.14 Beta (18A336e) and all works except Self Service.
Posted on 07-20-2018 10:45 AM
When enrolling my MacBook self service not coming.
Posted on 08-22-2018 07:54 AM
Its funny i opened Self Service in Mojave and i thought it was not working until i went to the title bar and clicked view >full screen.
and it worked just fine from there.
Policies worked fine the only thing that didnt work was installing of .PKG files for instance i could get office to install....
Posted on 08-22-2018 09:22 AM
For what it's worth: I had did not have any problem with Self-Service 9.101 on any of the Mojave betas.
Posted on 09-06-2018 11:22 AM
I have a computer running 10.14.0 (b7) and it just cannot find b10. Keeps telling me I am 'Up to date' ( on 18A365a)
Any tips and tricks that I might try to get it to update to b10?
Posted on 09-06-2018 11:25 AM
Self Service working fine for us in Mojave (beta 10) and Jamf Pro v10.7.0-b2.
Posted on 10-22-2018 02:51 PM
Installing Mojave and 75% of our MacBooks have had to be rebuilt from scratch. We also discovered that when we load Jamf onto a recently rebuilt MacBook caused the Mac to crash and we have had to re-build from scratch again! Either do not upgrade to Mojave or delete Jamf Now Self Service, until somebody works our what's going on.
