Posted on
10-22-2016
09:35 AM
- last edited on
03-04-2025
08:06 AM
by
kh-richa_mig
So, here's my issue. If I run a script via Policy to set the screensaver, it doesn't work.
<snippet>
/usr/bin/defaults -currentHost write com.apple.screensaver 'idleTime' -int "900"
</snippet>
Run that script as a policy via JSS and it doesn't set the value. Run that as a bash script from a terminal windows under the current user and it works fine. Run that same script again in Terminal with sudo and it doesn't set the value. "defaults read com.apple.screensaver idleTime" returns the current value, not the one I just tried to set.
In other words, no combination of script, Casper, bash running as root/sudo lets that script above run properly. It returns 0 to the JSS but doesn't actually do anything. It only sets the correct value under user context.
Oddly, if I take a completely different approach (thanks Macmule!) and run this code instead, it runs like a champ under all conditions.
<snippet>
startTime="900"
if [[ -n $startTime ]]; then
/usr/libexec/PlistBuddy -c "Add :idleTime integer $startTime" "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver."$macUUID".plist
</snippet>
So my question is two-fold. Why is running the first script effectively blocked when running as root. Am I hitting the issue where this thing is setting a screensaver only for root and therefore not available to the current user? If so, I would have thought that using the '-currentHost' switch would have set that parameter globally? Secondly, what is sufficiently different about the two script models that lets the second piece of code run properly?
This may be rudimentary, but I am a Windows person and so some of the subtlety here is escaping me.
Solved! Go to Solution.
Posted on 10-22-2016 11:22 AM
Marking this as Solved. Thanks @bentoms . I don't have a git repo I use regularly either so I am posting the full code here. I made 2 small changes to the original code posted here. I added/changed the command for the askForPassword parameter and I added a KillAll command to the end to kill preferences so the OS loads this one instantly.
startTime="900" # Integer - Seconds
justMain="0" # Boolean
screenSaverName="Shell" # String
screenSaverPath="/System/Library/Screen Savers/Shell.saver" # String
requirePassword="1" # Integer (1 = true, 0 = false)
timeBeforeRequiringPassword="5" # Integer - Seconds
askforpassword="1" # Integer (1 = true, 0 = false)
if [ "$4" != "" ] && [ "$startTime" == "" ]; then
startTime=$4
if [ "$5" != "" ] && [ "$justMain" == "" ]; then
justMain=$5
if [ "$6" != "" ] && [ "$screenSaverName" == "" ]; then
screenSaverName=$6
if [ "$7" != "" ] && [ "$screenSaverPath" == "" ]; then
screenSaverPath=$7
if [ "$8" != "" ] && [ "$requirePassword" == "" ]; then
requirePassword=$8
if [ "$9" != "" ] && [ "$timeBeforeRequiringPassword" == "" ]; then
timeBeforeRequiringPassword=$9
# Check if hardware is PPC or early Intel
if [[ ioreg -rd1 -c IOPlatformExpertDevice | grep -i "UUID" | cut -c27-50
== "00000000-0000-1000-8000-" ]]; then
macUUID=ioreg -rd1 -c IOPlatformExpertDevice | grep -i "UUID" | cut -c51-62 | awk {'print tolower()'}
# Check if hardware is new Intel
elif [[ ioreg -rd1 -c IOPlatformExpertDevice | grep -i "UUID" | cut -c27-50
!= "00000000-0000-1000-8000-" ]]; then
macUUID=ioreg -rd1 -c IOPlatformExpertDevice | grep -i "UUID" | cut -c27-62
loggedInUser=/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'
loggedInUserHome=dscl . -read /Users/$loggedInUser | grep NFSHomeDirectory: | /usr/bin/awk '{print $2}'
shopt -s nocaseglob
rm -rf "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver*
shopt -u nocaseglob
if [[ -n $justMain ]]; then
/usr/libexec/PlistBuddy -c "Add :mainScreenOnly bool $justMain" "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver."$macUUID".plist
/usr/libexec/PlistBuddy -c "Add :moduleDict dict" "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver."$macUUID".plist
if [[ -n $screenSaverName ]]; then
/usr/libexec/PlistBuddy -c "Add :moduleDict:moduleName string $screenSaverName" "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver."$macUUID".plist
/usr/libexec/PlistBuddy -c "Add :moduleName string $screenSaverName" "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver."$macUUID".plist
if [[ -n $screenSaverPath ]]; then
/usr/libexec/PlistBuddy -c "Add :moduleDict:path string $screenSaverPath" "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver."$macUUID".plist
/usr/libexec/PlistBuddy -c "Add :modulePath string $screenSaverPath" "$loggedInUserHome"/Library/Preferences/ByHost/com.apple.screensaver."$macUUID".plist
rm -rf "$loggedInUserHome"/Library/Preferences/com.apple.screensaver.plist
if [[ -n $requirePassword ]]; then
/usr/libexec/PlistBuddy -c "Add :askForPassword integer $askforpassword" "$loggedInUserHome"/Library/Preferences/com.apple.screensaver.plist
if [[ -n $timeBeforeRequiringPassword ]]; then
/usr/libexec/PlistBuddy -c "Add :askForPasswordDelay integer $timeBeforeRequiringPassword" "$loggedInUserHome"/Library/Preferences/com.apple.screensaver.plist
killall cfprefsd
Posted on 10-22-2016 09:45 AM
@johnmccrae I've a script I used to use for this years ago, posted here. Might be of some help.
Posted on 10-22-2016 10:09 AM
@bentoms Thanks! Yours was the script I finally used to get it working. It's brilliant. Do you accept pull requests? I made a couple of tweaks to it.
Posted on 10-22-2016 10:15 AM
@johnmccrae Awesome.
I could, but I don't really use that anymore.
However, if you have a fork posted I'll mention that & will link to it.
startTime=$4
justMain=$5
screenSaverName=$6
screenSaverPath=$7
requirePassword=$8
shopt -s nocaseglob
shopt -u nocaseglob
killall cfprefsd
