Posted on 10-08-2013 08:17 AM
Hello! I'm new to the JAMF world and am trying to create a policy that will encrypt a machine with FileVault at startup, but I need a script that will check for JSS policies at startup. I'm new to scripting as well, so any help would be greatly appreciated!
Posted on 10-08-2013 08:40 AM
You can create a policy set your triggered by to login, and set your execution frequency. Then add sudo jamf policy under advanced in the run command text field
Posted on 10-08-2013 01:25 PM
You can do this a few ways.
Smart Group all people who do NOT have File Vault Encryption and then set a policy to Encrypt at next login, etc.
Second is you could write a script that checks for file vault encryption and then encrypts if none is found.
