Need to bypass License activation prompt for Burp Suite
  • October 28, 2022
  • 740 views
Hello Everyone , I have created package for Burp Suite to install on systems automatically.
Post installation when I try to open the application then I get prompt to accept Terms and Conditions, thereafter getting License activation prompt to enter the License key .
It would be really helpful if someone has already installed the application and there might be some way we can skip this two prompts for end user by directly accepting the terms and conditions prompt and activate the license key from backend as soon as the application is installed on the system .
Since I'm new to this application ,any help will be really appreciated !!
1 reply
Forum|alt.badge.img+21
  • October 28, 2022
I can't say I have experience with this software, but a lot of apps lay down a .plist file (maybe in /Library/Application Support/) and if you build a package that installs THAT file to client devices, the app behaves as if it has already been run and registered when launched.
Just a thought.
